"Go to next sibling item" goes to invisible items
Set a shortcut for “Go to next sibling item” and/or “Go to previous sibling item”
Create a document with 3 items:
  • an unchecked item
  • a checked item
  • an unchecked item
Toggle hide checked items
Try using the shortcut to navigate between the unchecked items.
I expect to move between the visible, unchecked items.
“Go to next sibling item” from the first unchecked item results in the cursor disappearing. This is because it’s at the invisible, checked, item (which you can see by using the shortcut to zoom in on the present item). “Go to next sibling item” again finally brings you to the unchecked item.
I’m using desktop dynalist 1.1.14 on mac.
