Go To messed up with high zoom
  1. Zoom into the page
  2. Hit Cmd-O to open Go To pane
The Go To pane opens normally. I can type into it.
The Go To pane looks weird. Typing things actually types them into the document (a very annoying aspect of this bug!).
Chrome/macOS
Are you on the web or mobile? I can’t really hard from the screenshots… The expected result is a web screenshot whereas the actual result is either on mobile or on a different screen size.
@Erica I am on a Macbook, but the issue probably is Dynalist thinking I’m on mobile when I’m not.
