Give highlight of current line more contrast
I like the feature that highlights the current item to look lighter than the background for dark background and vice versa for light backgrounds. I find it a bit difficult to see the highlight on all parts of my monitor, though. Could the highlight contrast be bumped up a bit, or is there a workaround in my browser that will increase the contrast?
@Mark_Eichenlaub Do you code? If so, write a custom CSS stylesheet! If you use Chrome, try Stylish.
Thanks for the suggestion! I know enough about coding to know that tweaking the CSS would do what I want, but I didn’t know how to tell my browser to customize the stylesheet when loading someone else’s page.
I will give this a shot, although I don’t want everything to break with future Dynalist updates.
