the same content as export>plain text currently gives, but via a url
Like if your grocery list is at https://dynalist.io/d/wfdgjhegd#z=fdsghjfgwshd you could use https://dynalist.io/d/wfdgjhegd#z=fdsghjfgwshd.txt to view it in dumb devices like a smartwatch or kindle or web scraper of the month service
Or if your at home to do list has a .txt url you can open it on the kindle (after disabling sleep) to always have it in view on your kindle
stuff like that would be possible
I know we can get the document in json from the API, but has anyone on the forums figured out how to parse it to get a sublist of text, without hosting their own backend server? API is too hard. Thus my suggestion
