Export to GitHub Gist
I am a software developer. I want to export my dynalist item to GitHub Gist for version control and publication.
I suggest to put a new tab in the context menu of a document under “export”.
As a software developer, maybe you can try to utilize our API to do that?
GitHub Gist is frequently used by developers but not so much by normal users. I think having it as an export option will be a little confusing. To the same extent, people could ask for exporting to Google Docs, Confluence, Pastebin, etc… and that would make things crowded.
Thanks for understanding!
You guys have api? Amazing. Where I can find it? And how much?
The documentation is here: https://apidocs.dynalist.io/
This category is specifically for developers: https://talk.dynalist.io/c/developers
