Expand All
Dunno whether I am asking a silly question here… but how to expand all the item in a list? Is this possible in Dynalist?
I can see collapse all and undo the “collapse all” item. But is there a way to expand all the highlighted item, including all the sub-items of them?
There’s a keyboard shortcut for it. It’s Cmd-Shift-. for me, but hit Ctrl-? to open the help pane and check the exact shortcut for you.
Oh thanks! Expand all and collapse all are just the same key!
hey chris you mind marking your thread ‘closed’ if it’s solved?
not sure if the list of shortcuts was different at the time of this question
thx
Thanks for reminder #20char
