- Zoom a few nodes into a document so that you get breadcrumb navigation links at the top of the document.
- CMD-click or CTRL-click (depending on your operating system) one of the links in the breadcrumb navigation.
A new tab should open with that link.
The current tab navigates to the link.
Mac OSX
Which browser are you using?
Chrome
If youâre using a desktop or mobile app, whatâs the version number of Dynalist?
Not an app. Iâm using the browser.
No.
The breadcrumb links have event handlers attached to them and these event handlers donât account for the case where the CMD or CTRL key is being held down while clicking. This can be fixed easily by checking the event property evt.ctrlKey (itâs the same name on all operating systems):
As simple as this:
if (evt.ctrlKey) {
return true;
else {
return yourCurrentFunctionCall(params);
