Does not work on Samsung A71
Start a new document
Do be able to write the title. But the keyboard doesn’t work
It is like frozen and no keyboard shows
Samsung A71
Mobile app
Does it do the same when you use a browser to open Dynalist’s web version on your phone? Sounds like you’re able to login just fine but when you edit it doesn’t work? Does clicking on anything work?
Works fine in the webbrowser. But in the app you can’t write in the document or you can’t name a new document and write in that.
