after thinking about and based on my experience
and after knowing what the answer was
i was really surprised to see it was 50/50ish based on the small sample
neither of these two default are actually any ‘better’
because sometimes you want another ‘tabbed’ bullet *
but sometimes you want a blank line
i use blank lines (no it’s not call an item, that’s so dumb)
anyone that doesnt use blank lines
doesnt know how to use ANY note-taking software properly
because neither of these defaults are any better,
there needs to be a new innovative better solution
i picked the default to ‘tab’
for the best reason that this is fundamentally a list
and dyna is a list at the core
it makes much logical sense that a tabbed bullet *
would ‘tab’ upon the next line
it would not make any logical sense otherwise
but neither of these is better, it just makes more logical sense
it’s not practically better,
a tabbed list is not always or neccessarily better than a flat list
as a design choice, it is objectively & conclusively better
happy to consider any & all high quality points that directly counters anything that leads to a better answer than mines
