Hi - I often work in two instances of Dynalist (both in Chrome). In one instance I work in a “work” areas of miscellaneous notes. In the other area I refine the notes into finished text. But this morning the DISPLAY of the directories (left-side Nav Area) of my two instances are not staying separate. That is, the left-side Nav Area keeps syncing between the two, so that what is expanded/contracted is always the same in both instances. This makes it difficult to work on my 2 separate areas. Any help would be appreciated. (Is it possible Dynalist has always worked this way?)
Rex
