Disable the long-press activated menu on mobile
Since we have the ability to access the menu when editing a certain point, it would be nice to disable to the menu when long-pressing a bullet point, so that way it could be moved elsewhere.
Does anyone use the menu this way?
I don’t use this menu, given almost everything I need is present in the node toolbar menu.
Ah, ok. I wanted to make sure of that too. The menu can also be activated in read-only mode, which can be distracting.
