Deleting item within note doesn’t work
  1. Position cursor in note
  2. Hit keyboard shortcut to delete item
Item is deleted.
Nothing.
Chrome on macOS
If I remembered correctly, this was intentional, since someone complained that item shortcuts shouldn’t work in notes.
The shortcut should work because (a) it doesn’t do any harm: it doesn’t conflict with any other shortcuts that become activated in note mode, and (b) it does a lot of good: Deleting an item when in a note is a sensible thing to want to do, and I do it often.
The item shortcuts that shouldn’t work in note mode are the ones about selection/editing text that conflict with standard OS-level text shortcuts.
I agree with Yatharth! (Disclaimer: I complained about some shortcuts :p)
One shortcut that I use often and which was causing problems is Shift+↓. It’s been great since the fix. Ctrl+Shift+Backspace has no native function as far as I know, so it shouldn’t cause any problems in note mode.
