Del key deletes item with sub-items
Position cursor at the end of an item which has sub-items. Hit “del” key.
Either nothing. Or line break is deleted and next item is merged to the current item. Just like when hitting del on an item without sub-items.
The item with all subitems gets deleted. Something I’d only expect with CTRL+SHIFT+Backspace.
Windows. Chrome and Dynalist Windows App.
If this is by design it might be useful to be able to customize the key.
oo… can reproduce on Chrome/macOS.
I agree with the expectation of the first sub-item getting merged.
Sound scary. Hopefully @Erica and @Shida can take a closer look. Pinning this so that way other users will know, in case for some reason ctrl+z mysteriously doesn’t work.
@Shida is on it! Expect a fix out in 30 min.
Really sorry about that!
Seems to be working just fine on my end. Can you confirm, @Rainer_Kruschwitz?
Yep, the fix just went out to both web and desktop. A reload/relaunch should get the update pulled down.
Thanks again for the good finding (on a Saturday)!
You’re welcome. Major props to the OP and YA for reporting and confirming it. Thanks for taking the time to fix it ASAP! I’m glad it wasn’t something too complicated.
:slight_smile: Works like charm. Thanks for the quick fix.
