Dates can be selected in view mode
Enter view mode on mobile then click on any date
Nothing. Shouldn’t be able to edit date
Date selection comes up
Beta of iOS app. But I think it applies to web as well.
When we set out to implement View Mode the main purpose was to not let the keyboard pop-up, which was accomplished in your case. But I guess from the name of the view, it’s expected that the date editor shouldn’t pop-up.
Thanks for finding this!
