Date picker shows up at top of window for small screen size
  1. Shrink Chrome window to height < 500 px (till menu bar at top switches to the thicker one with hamburger menu at top left)
  2. Add a note and type ! or click the bottom menu calendar button to add a date
Date picker to show up right where I’m editing the line.
Date picker shows up above the top of the list. With a list of any appreciable length, this is way up above the current view box. I happened to scroll up to find it accidentally.
Chrome v73, web site version of dynalist.
Dynalist for Windows, 1.0.4
