Newb question. For a free tier user, are “customizable shortcuts” non-customizable, or entirely not available? I found 2 shortcuts that don’t work for me. As far as I understand, one of them is a “customizable” shortcut – Ctrl+Alt+Up/Down to move between sibling nodes, and the other one is a “regular”(?) one – Ctrl+Shift+. to expand/collapse all.
yeah keymap is pro
I know and read all of that. I might have missed the detail I am looking for.
Please point out the correct answer from these choices:
- Free tier users CANNOT customize any of these keyboard shortcuts.
- Free tier users DO NOT HAVE any of these keyboard shortcuts.
You should be able to use all the ones that dont say (Pro) next to them https://help.dynalist.io/article/91-keyboard-shortcut-reference
move up is just Ctrl+Up without the alt
try the other ctrl key? theres one on the left and one on the right. i remember one side had issues in the past.
