I find that paragraphs in the note field are difficult to distinguish. Is there a css code that would add spacing between the paragraphs? Thanks.
I’m not sure what format they are in. Perhaps rich text because the paragraphs are kept together. So it should be possible to have css code to control the spacing. I’ve not been able to figure what it is though.
i dont know what you mean by paragraphs
it’s lines of text
paragraphs are your choice
Hi Jimmy, unfortunately there’s no concept of paragraph here. You can enter an extra blank line for the visual purpose.
If you want, you can adjust the line spacing as you wish with custom CSS though.
Okay, thank you.
