Greetings friends: Is there a way to create a new document in an existing folder? It seems when I have a file open then I click ("+") the document immediately goes to the top. I would like to keep the new document in the current folder. Thanks.
Just right-click on the existing folder and you will see the “New Document” option. Click on it and a new document will be created within the existing folder. And you can also drag and drop any document into an existing folder. Good luck!!
Many thanks Ashraf for your prompt reply. Very helpful. Much appreciate the good customer service.
