Create new bullets, zoomed in, should be collapsed in outline
  1. Find a bullet you want to add other bullets to
  1. Either click on it to zoom in or use keyboard shortcut
  2. Create new sub-bullets
  3. Click back to your main list from which you can see the bullet listed under 1
The main bullet with its sub-bullets collapsed
The main entry is expanded
Chrome/Windows 10[poll]
  • Current behavior is ideal.
  • Proposed behavior (expected result) is ideal.
    [/poll]
Moved this to features as its working as intended, although the outline for the bugs post is useful.
