I am hoping there is some way to view (only) all checklist items across multiple lists (or really, just within one list would be a start). Am I missing some obvious way to do so?
Same question but for dated items. (Yes, I know I can sync to gCal)
If they are all in the same document, you can filter the view down using https://help.dynalist.io/article/93-search-operators-reference
Press command-F and paste has:checkbox OR has:date
You can copy the URL from the address bar to save the link to this filtered view as well.
Thank you!
