Confirmation dialog for folder deletion says "file" not "folder"
Create new folder
Right click on folder and select delete option
‘Deleting folder
‘Are you sure you want to delete the folder “Untitled”?’
‘Deleting file
‘Are you sure you want to delete the file “Untitled”?’
Windows 7, Chrome Browser.
Just a minor cosmetic issue obviously.
There’s no warning either that all files in the folder will be deleted, if you go ahead and delete, which some might appreciate.
Technically a folder is also a file, but I understand what you mean.
Although I think that’s pretty obvious to most people, yeah, adding that part doesn’t hurt either.
