Clicking in collapsed folders should open them
Basically, instead of having to tap on the caret, tapping on the name should open (or close) them.
It used to that way, until we thought closing right after opening feels annoying when you just want to double click to edit the name.
@Shida wants the behavior you described here as well. Maybe we should bring it back instead.
Ah, I see your point there, but naming happens once most of the time.
Cool. I guess the cursor should be a hand cursor rather than a normal pointer when you hover the folder name?
I think I would leave it as a mouse, so that way someone would know that if they click on it enough (twice) that they can rename it, just as they can with a document.
What about clicking once to expand/collapse folders, and clicking twice to rename?
Great suggestion, this is what we thought originally as well.
The problem is that there does not exist a handler called “click once”. The “click” action will be triggered twice when a user double clicks. The only way we know of to distinguish is to wait for the second click and if it doesn’t happen, understand it as a single click. This is the closest approximation to “click once”. The problem of course, is that there’s a slight delay after you click, because we’re not sure if you want to click a second time yet.
The delay should be around 300ms and it’s pretty noticeable.
