Checking of tags with ALT click shifts the screen when it brings up the Menu
When you search up tags and process them by clicking ALT+left mouse click, the Meny in the UI is toggled on/off - which shifts the whole screen up/down. This is annoying as the text moves as you are about to click. There should be an option to always show the menu so this did not happen. I repeatedly miss the tag as the screen shifts when I press Alt and is about to click the tag.
The note part of the screen should NOT shift when you press ALT. Give an option to always show the menu?
Windows 10 - 1809
DynaList 1.1.15
Pls advice. Thanks.
/lars
