Make an item with a tag in it, for example
Test @item here
Put cursor inside “#item”, for example, between the “t” and “e”. Use a keyboard shortcut to change the color highlighting of the item
Item color highlighting changes.
Item color highlighting changes, but also a dialog comes up with a bunch of tag to select for completion.
Windows 10 app
I often use keyboard keys to move up and down through a list of projects, each with a tag. When I change the color on one of these items, this tag completion dialog comes up unexpectedly. Then I can’t use the up and down arrows to move through the tags any more because they start moving a selector up and down in the tag completion menu.
