This doesnât always happen, only sometimes. This is what I do:
- tap cmd-shift-I
- dynalist should be in the foreground, with the âcaptureâ dialog focused
- nothing seems to happen
- I think that in the dynalist app, the capture dialog has been brought up, but Dynalist hasnât been brought to the foreground. Iâd need to pay more attention to this in the future to see if this is actually the case
- macOS 10.15.6
Which browser are you using?
- Native app 1.4.1
If youâre using a desktop or mobile app, whatâs the version number of Dynalist?
1.4.1
No
after I try the keyboard combo and it doesnât bring dynalist to the foreground, if I manually bring dynalist to the foreground and then bring another app to the foreground and try the kbd combo again, it works! iâm guessing dynalist gets into some weird state occasionally and bringing it to the foreground fixes it
