- Have no documents open, (not exactly sure how to do that, but I think itās whilst searching and breaking away from search).
- Try to tap on the magnifying glass at the top.
The search bar should appear or activated(?).
Nothing.
Android 7.1.1, Chrome (and Hermit).
Basically tapping on the magnifying glass doesnāt do anything.
