Can't scroll settings in mobile web
  1. Open settings using 3-dots icon in top-right
  2. Try to scroll down
I scroll down the settings pane.
The settings pane doesn’t scroll down. Instead, it seems the list stuff hidden behind the settings pane is what is getting scrolled.
Chrome on iOS
I can reproduce this issue on iPad but not iPhone.
Did it also happen to you on an iPad?
Yep, happened on my iPad. Haven’t tested on my iPhone.
It’s weird that the behavior is different on these two devices… will take a look!
Thanks for reporting this! :heart:
