Can't Rearrange Bookmarks
Can’t rearrange bookmarks on web, Chrome or Firefox.
Dragging & Dropping Bookmarks to Rearrange Them
Pointer cursor changes to grabbing cursor and box pops up showing the bookmark to be moved, but doesn’t actually move.
Windows 7 (work computer), Chrome 57.0.2987.110 and Firefox 52.0.1. Doesn’t work in either mode, desktop or mobile view.
Seems to have started around when dragging document to create item was announced, 3/20/17.
Perhaps related or I can submit as separate bug, but dragging document to create an item doesn’t work either. Rearranging documents does work.
Thanks for the report, I think I tested it initially after releasing dragging document to create item, maybe another release after that broke it.
Will look into it, thanks!
Update: this should be fixed now!
Rearranging bookmarks works…thanks!
