Can't drag a file into a folder or use a folder for anything?
I’m trying to drag a document into a folder but the system doesn’t allow it. I can only drag it under or over.
Also, I can’t open a folder in order to start a new document in that folder, so currently, I can’t use folders for anything.
Anyone know how to fix this? I’m using the web based version with the latest Chrome browser.
When dragging, land at the right end, that will drag it into the folder.
There’s no “opening” the folder like in file explorers – you use folders by expanding them and collapsing them once they have content.
I hope that helps!
