Can't access drop-down, Right-Click menu for 'My Files' sidebar on mac
I go to delete a File or Folder from the ‘My Files’ sidebar using Ctrl / Click (on trackpad, no mouse)(this is the Right-Click equivalent gesture).
I would expect to get a drop-down menu that would give me a ‘Delete’ option as shown in your tutorial.
Nothing happens. No menu shows up.
Which operating system are you using? macOS Mojave 10.14.6
Which browser are you using? Safari v13.0.3
If you’re using a desktop or mobile app, what’s the version number of Dynalist? Because I can’t access a drop-down menu, I can’t tell you.
Anything else you think would help our investigation, like a screenshot or a log file? You can drag and drop screenshots to this box. For large amount of text, try putting them into something like Pastebin. None
Additional comments. None
Can confirm issue. Fixed in code and will be deployed in a future patch.
