- Open search field.
- Enter some text.
- Press
Shift+Enter
- Press
Esc
for āGo backā.
- Search field should has a focus.
Shift+Enter
andCtrl+Enter
work.
- There is no focus on search field, I canāt type something without mouse or many
Tab
s. - Any holding
Shift
orCtrl
keys will do previous type of search (āFlatā in this case), so you canāt do another search (āSearch in all documentsā in our case). And itās vise-versa: if youāve pressedCtrl+Enter
andEsc
ā you canāt pressShift+Enter
then, because on shift it doesCtrl+Enter
again. Until you delete an entered text.
Arch Linux, Chromium Version 83.0.4103.116, website.
Nothing.
Itād be better to mark in the hotkeys panel on the right that Ctrl+Enter
works in Search bar, not everywhere.
