Be able to unfold / fold in search view
In Workflowy, you are able to unfold nodes in search mode, and see subnodes even if they do not match the search query. This is immensely useful for quick navigation, please implement that.
Interestingly, if I go through the context menu, I can select “collapse”, and then also the +/- appears for collapsing / expanding. So maybe it is just a bug that this is not shown up front?
Hi @lucasbrut,
Yes, that’s indeed a bug that we’ll prioritize on fixing.
In addition to the context menu, you can use the Ctrl+. shortcut to expand.
