Background keeps defaulting to sepia instead of "default"
Whenever I refresh or open a new window with my page, it always switches from default (my preference) to sepia.
I expect the background to remain as I left it, not to keep switching back to some internal preference.
I am using Chrome on a Macbook running El Capitan.
Just tested it and can’t repro…
Sounds like the preference didn’t get saved though. Could you manually set it again? (Set it to Sepia and to Default again)
Also it would be really weird if you have never set the theme to “Sepia”. Have you set it to Sepia in the past?
Hi @Emlen_Metz, sorry for digging this up :grimacing:! We’re cleaning up the bugs and would like to know if the bug is still happening to you? If not we’ll close this bug :slight_smile:
