Autoformating multi level lists
If you create a multi level list, e.g.
item 1
  • item 2
  • item …
    item n
And then you select both of those and press Ctrl+b or Ctrl+i etc.
I would have expected every list that is selected (highlighted in blue box) to be formatted. However, if item 1 was collapsed, then only item 1 and item n to be formatted, as the sublists are not selected.
Only item 1 and item n are formatted, despite item 2 and onwards being selected. i.e. only the lists on the same level as the first list selected are formatted.
OS: Windows 10
Browser: Google Chrome
Example of result
Thanks for the detailed bug report (plus following the bug template perfectly)!
Will fix soon :sunny:
Update: the bug is now fixed and the fix will be released soon. Will update again when it’s released and live.
BTW something I just thought of: you can also upload screenshots right here, if you haven’t discovered.
Yeah I found out recently :sweat_smile: Thank you:)
Np! You don’t need to save space for us :slight_smile: .
Update: this bug should be fixed in the latest version. After refreshing you would be able to see it.
Let me know if it still doesn’t work for you!
