Autocomplete tag with Exclude operator not working in Search
When performing a normal search begin with the exclude operator as
or
List of tags available as per the results when no exclude operator is used in a search
Nothing is shown in the autocomplete list
Win 10
Chrome Latest
No other options apps or scripts installed
Works in workflowy and commonly used as #task -#notassigned
Will be fixed in the next patch
Many thanks, appreciate the rapid response
