Does anyone know if it’s possible to add some kind of css animation to a checkbox as you check, then uncheck it?
…I’ve tried adding stuff like transition:.4s
and @keyframes...
into the mix, but haven’t been able to get anything to work.
I’m starting to think it’s not possible.
