Hold ALT and press 4 on the number keypad
I want to hold ALT and use combinations with 4 to access alt symbols
It takes me to another Dynalist section when I press the 4. If the number combination is longer than 4 (eg 240), after taking me to the other section it will insert the symbol.
Windows 10 Firefox current.
Nope.
Nope.
