Advanched Search Query for Next Actions
Really Like to have an option to search two filters
Example now :
Within:1w
Example future :
Within:1w and not: completed
Now this can work with an workaround to change the overall setting to disable completed actions. But i really like to use this particular only within this search results which i captured as Bookmark “Next Actions”.
Cheers
Dimitry
Try:
within:1w -is:completed
Use the - to negate the 2nd search term, ‘not completed’
I think @DimitryJacobs knows how to do it, he just wants additional search query shorthands like “today”?
@Keith_Crone and @Erica wasn’t aware that you can use negative parameters, will test it later today brings up an whole lot of ideas :man_scientist:t2::alembic:️:heavy_check_mark:️
