Open menu in any item
Select Add checkbox
Add checkbox for the item
Did not add checkbox for the item
Which browser are you using?
Windows 10 / Google Chrome
Use shortcut work, but I usually donāt use shortcut to add checkbox
Add checkbox to children work
