I used project-based documents with the first level organization being custom to each project. Once inside these first level nodes, I have tagged details of things to do at arbitrary levels of nesting interspersed with notes, links, etc, for example: #today
#w-i-p
#expect
#k-i-m
#due
#William-XYZ
#Project-ABC
etc.
What would be nice would be to able to manually place a compound bookmark for a particular document (like links are) anywhere inside the document, maybe in the first top-level node where I could quickly get to search combinations .e.g. #w-i-p OR #today OR #urgent
, or maybe #expect #William-XYZ
These searches are presently in the bookmark pane amidst many others and it is takes far too much time to find the looked-for bookmark when you need it.
Presently, I am typing in the search specs inside the document, which works well, but this would be a big productivity improvement for me. I do get that this style of using DYNA may not be broadly used and so this could be a long-tail type of ask.
I’m a BIG fan of DYNA regardless,
Fraser
