I have two bookmarked flat search results (Next Actions and Next Actions Work).
After clicking on any of these pages, I go to a task and want to create a new item inside. Sometimes it works, sometimes it doesnât. It doesnât give a bullet point after hitting Enter. Just a plain text. I suppose somehow it makes it hidden.
Also, keyboard shortcuts just donât work in these cases. The only solution is to close the program and open it again.
It happens both in Chrome browser and Web App.
Here is a gif:
Here is a full video of how it happens: Video bug
I expect to have a bullet point appear and keyboard shortcuts to work.
No bullet point and no possible work. The solution is to restart the app.
Windows 10
Which browser are you using?
Chrome
If youâre using a desktop or mobile app, whatâs the version number of Dynalist?
Dynalist 1.4.5.
No
