Hi there. Continuing to enjoy the product. Slowly starting to shift away from others I use. Thanks for all you do.
Trying to understand support for images. A few use cases:
- If I right click and “copy image” from a web page and try to paste it into a Dynalist item, nothing happens (Windows app or Web)
2a) If I drag an image from a web page and drop on a Dynalist item, it will drop in, but cannot be resized.
2b) Note this does NOT seem to work in cases where the web image does not have an image extension (such as jpg). For example using this image does not seem to work
2c) If I drop the image into the Windows app, it will not show up on the Web (even after syncing). And vice versa as well
If I manually take a screenshot of an image and then paste that in, it does paste in, but cannot be resized
If I “copy image address” from a web page and paste, it pastes in the URL, but not the image itself. This is probably expected behavior
The link provided for more information at the bottom of this page appears to be dead
Note I do have the display images inline setting turned on.
Could you just generally advise on the above? My most common use case would be #1 above, so for that not to work is a challenge.
Thanks
