What is this forum built on?
Hey :slight_smile: I was wondering what tool was used to build this forum and the FAQ page. Is this an internal tool? Or is it using something else? Are there good free tools people would recommend for help forums and for FAQs? Thanks!
ah! thanks :slight_smile:
protip:
run wappylzer and builtwith chrome extensions to know what software something is running. Generally will tell you if it knows what platform it is or isn’t
Its built by jeff atwood from codinghorror
Or builtwith Technology profiler extension which I do prefer.
Interesting! Thanks @Mk1 and @Vincent_Tang
