Is there a way to start editing the document after opening it with the file finder without using the mouse? After opening a document using the file finder, there is no cursor available. I have to use my mouse to select the line I want to edit. It would be nice if I didnt have to do that.
Same issue when I search. If you search via workflowy, pressing the down arrow brings you into the search results
