dynalist app on mac OS. A title to the page which has extended onto 2 lines because of word wrapping. Moving the cursor between the title and the bullet points doesnât work.
Should be able to move cursor up and down using the keyboard arrows
Down arrow works as expected. Moving up arrow works fine through bullet points, gets to the second line of the title and wonât go up to the first line
Mac Sierra Dynalist app - actually the same problem in Safari, just tried it
