Unusual scrolling when multiple rows are selected
duplicate
tracked
I’m not sure exactly how to reproduce this.
  • Use Dynalist for a while, doing stuff
  • press shift + down to highlight a row
  • press ctrl+down
highlighted row moves down one place in the list
Dynalist scrolls back up to the top of the list
Windows 10, Windows App 1.0.47
I don’t know what triggers this bug. It goes away if I exit and re-open Dynalist, then every once in a while comes back. If I notice a pattern to what I’m doing before this behavior starts, I’ll update this post.
I’ve found that switching documents causes this bug to go away; I don’t have to completely exit Dynalist.
Page scrolls to top when moving multiple items with keyboard
Thanks for the follow-up!
Is this bug always reproducible after switching to a new document?
Also this seems to be a duplicate report of an earlier post:
Yes, it’s a duplicate - I didn’t see that report. Thanks!
