UI Glitches iOS not alligned
Focus on sub items in my document to see breadcrumbs
In Breadcrumb > is at the same height as the text
Normal margin so number list are better to read
In Breadcrumb > is not at the same height as the text
Wrong margin so number and text are merged and not readible
iOS, macOS
Thanks for the details. @Erica, please have a look when convenient.
Hi @DimitryJacobs, the first issue seems to be caused by the emojis, as described in another post.
Regarding the second numbered list problem – what’s your font size and list density setting?
Hi @Erica
These are my settings i used
Font size : small
List density : comfortable
Font : Whitney
(@Erica)
@DimitryJacobs: I just tested again, looks like the text merging problem is better (at least the 10th bullet point looks better than your screenshot), but the vertical alignment is still a little off.
@JP1, thanks for the ping!
Hi @DimitryJacobs, sorry for digging this up :grimacing:! We’re cleaning up the bugs and would like to know if the numbered list bug is still happening to you? If not we’ll close this bug :slight_smile:
Looks like the bug is not anymore active in the last version see my screenshot as example
