I understand as a new member I have a 14 day trial of pro features. I donāt have this tag pane.
EDIT: the web view has it. The desktop (Windows) view does not.)
Please restart the app, sorry for the inconveniences!
I wonder what should be under there, a list of all untagged items with their full notes? Looks overwhelming especially if a person doesnāt tag everything (that might be the majority of users, since I canāt image myself tagging things like book notes and meeting notes either).
Right, my bad; I meant it to open a list of all untagged notes in the main window, like itās a separate file. Not a drop down like #tags, of courseā¦ Anyway, I still want folders:D What do you mean by ācreate, maintain and updateā? How are tag folders fundamentally different from file folders? Coding-wise it shouldnāt be that hard, come on. Hereās what I think it should look like:
Itās not perfect by any means, just a basic visualization.
Alright now, isnāt that looks amazing?!?!one
Tags are dramatically different than files. Files are saved on our server and are persistent, whereas tag counts are counted each time you open Dynalist or edit something, so they are fresh on each restart.
Given this, you should understand why itās hard to add folders to tags. Tags do not persist, and tag folders need to persist. More accurately, itās not technically hard, but itās not elegant design given the current state, since tags will be kept in two different ways (1. computed from scratch and 2. saved in folder data). So weāll need to think more about how to properly do it.
I really hope that this feature of having the tag pane also show tags at the current zoom level is still planned. It would make it so much easier to tell at a glance the contents of dense parts of any given document. Ideally this part of the tag pane would also display only the tags present within search results after a search is conducted. That would be so powerful. Any chance this feature could at least be added to Trello so it can start moving up the chain?
You can start with posting a feature request in the forum and see if others are interested in it as well.
If the answer is yes, we can add it to the Trello board!
+1 for Tag Folders!
Tags for the current zoom is an absolute MUST for me - I have extensive and dense tags on my bullets to organize research, and I want to know which tags are available to sort the data with the current zoom level. Thanks!
Couldnāt folders for tags be solved with a separator?
Like:
@Folder|Tag1
@Folder|Tag2
Would look like this:
Folder
