Erica
I think the tag pane is a great step in improvement for dynalist
However, I feel like its missing some things:
- Thereās just way too many tags right now and really low amounts of real estate to see what I need to see
I was hoping for something very similar to evernoteās UI tagging system panel. Which has the following features:
- Ability to sort tags based on folders (folders sit at the very top)
- Most recently added tags are the first ones seen on top of queue, but below folders
- Ability to āShortcutā tags. Although bookmarks does this already
- Ability to group and bulk move tags to folders easily
For me, I would say the number one use for tag pane is to help me analyze how which tags I am using most often, and which ones I am not really, and to understand my relationships between tags. Also, in evernote, I nest tags inside tags, this helps me understand what the relationships of tags are. For instance, in evernote I had:
- Client Tags
ā Client 1 tag
ā Client 2 tag
ā Client 3 tag
ā Client 4 tag
I treat evernote tags like folders in evernote. So I could have a tag that appears in two different parent tags
- Client Tags
ā Client 1 tag
ā Client 2 Tag
ā Client 3 tag
ā Client 4 tag
- Ongoing client tags
ā Client 1 tag
Ideally, I would say, that the tag pane should be able to āexpandā into a full dashboard (taking up entire screen), but dynalist doesnāt have support for this yet though. If Iām organizing tags, I want my whole screen with the ability to see and organize all tags at the same time, similar to evernote
Granted, I never navigated my evernote notes via tag panes manually eitherā¦ It was just there to ensure I understood how my tags related to each other. It helps me understand the big picture in my notes. Its very similar to why I write a SOP(standard operating procedures) despite the fact I almost never look at it
Evernoteās tagpane UI definitely is the best in class, and should be followed for future improvements in my opinion
