The prerequisite to getting stuff to disappear is probably inconstant internet connection. If you make an edit in two devices and then sync, thatâs when it can go wrong. And specifically if the operation in one of these places is to delete something.
The reason this comes up is probably because there isnât necessarily a constant relation between the content of a node and the node itself. You can press enter to split a node or create a blank node, you can cut / paste stuff, and on another device that wasnât synced, you might delete what looks like an irrelevant line, but on the other end it had become relevant content. But at sync that relevant content is deleted.
I think the ideal solution would be a recycle bin document where anything that gets deleted gets sent to that bin where you could visit and Move back in. This must include content that gets sent to the server after the contentâs node is deleted. Currently Dynalist discards such because thereâs nowhere to put it.
By the way, even though Iâm a die-hard DynaLister, this issue is why I do not and have not recommended everybody at my work team get the tool to share notes. Itâs just too dangerous. As a solo worker I can avoid these bugs. If this were resolved Iâd change my tune.
